Прошу посмотреть альтернативу для замены своего хая от этого зависит судьба выбора, не охото менять то, что прощупал своими руками на проблему.
JTEEP21A450107477
Год выпуска:2005
Производитель:Toyota
Модель:Highlander Base / Limited
Тип кузова:SUV 4D
Тип двигателя:3.3L V6 SFI
Страна производитель:Japan
Количество записей в базе:14
03/14/2005 NICB Vehicle manufactured
and shipped to original dealer
03/31/2005 63 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Vehicle sold
04/15/2005 New Jersey
Motor Vehicle Dept.
Voorhees, NJ
Title #SL20051050163 Title issued or updated
First owner reported
Titled or registered as
personal vehicle
05/05/2005 3,910 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Oil and filter changed
07/06/2005 8,656 Champion Toyota
Philadelphia, PA
215-742-9300
Brakes checked
10/10/2005 17,501 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Battery serviced
Engine serviced
Tire repaired
Rear brakes serviced/adjusted
12/19/2005 22,538 Champion Toyota
Philadelphia, PA
215-742-9300
02/15/2006 27,940 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Rear brakes serviced/adjusted
Cabin air filter replaced/cleaned
Brake pads replaced and rotors resurfaced
Tires rotated
04/12/2006 33,131 Champion Toyota
Philadelphia, PA
215-742-9300
05/26/2006 36,535 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Rear brake pads replaced and rotors resurfaced
06/29/2006 38,129 Champion Toyota
Philadelphia, PA
215-742-9300
08/11/2006 44,276 Champion Toyota
Philadelphia, PA
215-742-9300
10/05/2006 49,926 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Recommended maintenance performed
Four wheel alignment performed
Tires rotated and balanced
11/14/2006 53,187 Champion Toyota
Philadelphia, PA
215-742-9300
Tire condition and pressure checked
Exterior light bulb(s) replaced
12/22/2006 Champion Toyota
Philadelphia, PA
215-742-9300
01/11/2007 60,000 Pennsylvania
Motor Vehicle Dept.
Dublin, PA
Title #64139617PA01 Title issued or updated
New owner reported
Loan or lien reported
01/27/2007 63,692 Champion Toyota
Philadelphia, PA
215-742-9300
02/28/2007 66,676 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Emissions inspection completed
Safety inspection completed
04/30/2007 71,898 Champion Toyota
Philadelphia, PA
215-742-9300
Four tires mounted and balanced
06/26/2007 77,674 Champion Toyota
Philadelphia, PA
215-742-9300
Tires rotated
08/20/2007 83,158 Champion Toyota
Philadelphia, PA
215-742-9300
sloaneautos.com Engine/powertrain computer/module checked
10/09/2007 88,291 Champion Toyota
Philadelphia, PA
215-742-9300
Transmission checked
Fuel injection system flushed/serviced
Transmission fluid changed
Air filter replaced
Power steering fluid flushed/changed
11/20/2007 92,621 Champion Toyota
Philadelphia, PA
215-742-9300
12/28/2007 95,806 Champion Toyota
Philadelphia, PA
215-742-9300
Engine checked
Tires rotated
02/22/2008 101,613 Champion Toyota
Philadelphia, PA
215-742-9300
02/26/2008 Pennsylvania
Motor Vehicle Dept.
Perkasie, PA Registration updated when owner moved
the vehicle to a new location
05/15/2008 Champion Toyota
Philadelphia, PA
215-742-9300
07/18/2008 112,939 Champion Toyota
Philadelphia, PA
215-742-9300
10/01/2008 119,121 Champion Toyota
Philadelphia, PA
215-742-9300
12/27/2008 124,272 Champion Toyota
Philadelphia, PA
215-742-9300
One tire mounted and balanced
Front brake pads replaced
Front brake rotor(s) replaced
01/02/2009 Pennsylvania
Motor Vehicle Dept.
Perkasie, PA
Title #64139617PA01 Registration issued or renewed
03/12/2009 Damage Report
TOTAL LOSS VEHICLE
- There are many reasons an insurance company will declare a vehicle a total loss. Have this vehicle inspected by a qualified technician before you buy. Learn more
03/12/2009 Pennsylvania
Motor Vehicle Dept. Title or registration issued
to insurance company
03/12/2009
125,220 Pennsylvania
Motor Vehicle Dept.
Concordville, PA
Title #64139617ST01
SALVAGE TITLE/CERTIFICATE ISSUED
05/15/2009 Vehicle Exporter Vehicle exported from
New York, NY
and imported to
Lithuania
10/21/2010 Toyota Motor Sales, USA, Inc. Manufacturer Recall Issued
NHTSA #10V499
Recall #A0M Safety Recall A0M - Certain 2005
through 2006 Model Year Toyota Avalon Vehicles &
Certain 2004 through 2006 Model Year Highlander
(Non Hybrid) Vehicles Brake Master Cylinder Cup
Replacement
Status: Remedy Available
Locate an authorized
Toyota dealer near you to schedule an appointment
Learn more about this recall
02/24/2011 Toyota Motor Sales, USA, Inc. Manufacturer Recall Issued
NHTSA #11V112
Recall #B0A Safety Recall B0A - Certain 2004 ?
2006 model year Highlander/Highlander HV Driver's
Side Floor Carpet Cover and Retention Clip
Description: Toyota is recalling certain Model Year 2004-2006 Highlander, Highlander Hybrid, and Model Year 2004-2007 Lexus RX330, RX350, and RX400h vehicles. If the forward retention clip used to secure the floor carpet cover, which is located in front of the center console, is not installed properly the cover may lean toward the accelerator pedal and interfere with the accelerator pedal arm.
If this occurs, the accelerator pedal may temporarily become stuck in a partially depressed position rather than return to the idle position. A stuck accelerator pedal may result in unintended and sustained vehicle speeds and make it difficult to stop, increasing the risk of a vehicle crash.
Remedy: Dealers will replace the floor carpet cover with a newly designed one free or charge. Owners may contact Toyota at 1-800-331-4331.
11/09/2011 Toyota Motor Sales, USA, Inc. Manufacturer Recall Issued
NHTSA #11V539
Recall #B0M Safety Recall B0M - Certain 2004 and
2005 Model Year Camry, Camry Solara, Highlander,
Sienna, Solara, certain 2004 Model Year Avalon and
certain 2005 and 2006 Model Year Highlander HV
Vehicles - 1MZ-FE/3MZ-FE V6 Engine Cranks
База NICB пишет, что было столкновение (какое, хз_
VIN: JTEEP21A450107477 has been identified as a vehicle listed in the VINCheckSM Salvage Records.
Date of loss: 2009-05-11
Cause of loss: Collision
