By Dealer 01/25/11 Galaxy Toyota 147,938 0157752 NO 27PT INSPECTION AT THIS TIME View Details
By Dealer 01/25/11 Galaxy Toyota 147,938 0157752 PERFORMED DIAG TEST, NO POWER NO START HYBRID, INSPECTED W/ENGINEERS ..NEEDS INV View Details
By Dealer 11/23/10 Galaxy Toyota 143,624 0155180 CUSTOMER STATES PERFORM, LUBE OIL AND FILTER CHANGE. REPLACE DRAIN PLUG GASKET.T View Details
By Dealer 09/30/10 Galaxy Toyota 139,270 0151879 CUSTOMER STATES PERFORM, LUBE OIL AND FILTER CHANGE. REPLACE DRAIN PLUG GASKET.T View Details
By Dealer 09/30/10 Galaxy Toyota 139,270 0151879 TUNE UP WITH PCV VALVE , AIR FILTER AND CARBON CLEANINF View Details
By Dealer 09/30/10 Galaxy Toyota 139,270 0151879 PERFROM ELECTRONIC FUEL INJECTION SERVICE View Details
By Dealer 09/30/10 Galaxy Toyota 139,270 0151879 PERFORM THROTTLE BODY CLEANING PROCEDURE View Details
By Dealer 09/30/10 Galaxy Toyota 139,270 0151879 CUST IS AWARE THAT 2 TIRES ARE NEEDED View Details
By Dealer 07/14/10 Galaxy Toyota 132,785 0146836 WAS ADVSIED OF NEEDED TIRES View Details
By Dealer 07/14/10 Galaxy Toyota 132,785 0146836 CUSTOMER STATES PERFORM, LUBE OIL AND FILTER CHANGE. REPLACE DRAIN PLUG GASKET.T View Details
voobshe tam 65 zapisey
Vehicle: 2006 Highlander hv JTEEW21A560013399
1. Safety Recall B0J (B1J - Interim) - Certain 2006 through 2007 Model Year Highlander HV Vehicles Intelligent Power Module (IPM) Replacement
Code: B1J
Memo
At the present time, Toyota is developing the remedy for this safety recall. Toyota will notify owners of covered vehicles by first class mail. The first notice will inform you that toyota is currently developing a remedy and second owner notification will be sent when the remedy is available. Please continue to check this site for additional information.
What is the Condition? The Intelligent Power Module (IPM) is located inside of the Hybrid System Inverter and contains a control board with transistors. Certain transistors on the control boards of some of the subject vehicles were inadequately soldered and could be damaged from heat caused by a large current during high-load driving. If this occurs, various warning lamps will be illuminated on the instrument panel. The vehicle may enter a fail-safe/limp-home mode that limits the drivability of the vehicle. It is possible that the hybrid system will shut down while the vehicle is being driven, causing the vehicle to stall unexpectedly, increasing the risk of a crash.
2. Safety Recall B0A - Certain 2004 2006 model year Highlander/Highlander HV Drivers Side Floor Carpet Cover and Retention Clip
Code: B0A
